BIOS PC TROOPER B150 D3
Discussion in 'BIOS/UEFI' started by technical, Oct 7, 2015.
    ASUS TROOPER B150 D3
    BIOS TROOPER-B150-D3-ASUS-0212 16MB
    Best-value TUF B150 ATX board with military-grade components and cooling tech to guarantee 24/7 durability
    • TUF Certified 24/7 durability - Promised Reliability with Strict Testing
    • TUF LANGuard - Exclusive military-grade LAN protection
    • TUF ESD Guards 2 - 2X Stronger ESD protection for extended component lifespan
    • TUF Audio Design– LED-lit shielding and noise reduction
    • TUF Thermal Radar Core - Complete System Cooling, Customized Fan Tuning
    • TUF Components [Caps, Chokes & MOSFETs; Certified by Military-standard] – Certify for Tough Duty
      Intel® Socket 1151 for 6th Generation Core™ i7/Core™ i5/Core™ i3/Pentium®/Celeron® Processors
      Supports Intel® 14 nm CPU
      Supports Intel® Turbo Boost Technology 2.0
      * The Intel® Turbo Boost Technology 2.0 support depends on the CPU types.
      * Refer to www.asus.com for CPU support list
    • Chipset
      Intel® B150
      2 x DIMM, Max. 32GB, DDR3 1600/1333 MHz Non-ECC, Un-buffered Memory
      Dual Channel Memory Architecture
      Supports Intel® Extreme Memory Profile (XMP)
      * Refer to www.asus.com for the Memory QVL (Qualified Vendors Lists).
      * To prevent system instability, either install DDR3L DIMMs or DDR3 DIMMs with voltage lower than 1.5V.
      Integrated Graphics Processor
      Multi-VGA output support : DVI/RGB ports
      - Supports DVI with max. resolution 1920 x 1200 @ 60 Hz
      - Supports RGB with max. resolution 1920 x 1200 @ 60 Hz
      Maximum shared memory of 1024 MB
      Supports Intel® InTru™ 3D, Quick Sync Video, Clear Video HD Technology, Insider™
    • Multi-GPU Support
      Supports AMD Quad-GPU CrossFireX™ Technology
      1 x PCIe 3.0/2.0 x16
      1 x PCIe 3.0/2.0 x16 (x1 mode, black)
      1 x PCIe 3.0/2.0 x16 (max at x4 mode, black)
      2 x PCIe 3.0/2.0 x1
      Intel® B150 chipset :
      6 x SATA 6Gb/s port(s), black,
      Intel® Rapid Storage Technology supports
      Realtek® RTL8111H, 1 x Gigabit LAN Controller(s)
      Realtek® ALC887 8-Channel High Definition Audio CODEC
      - Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
      Audio Feature :
      - LED-lit Audio Shielding: Ensures precision analog/digital separation and greatly reduced multi-lateral interference, with a gorgeous illuminated trace path
      Separate layer for left and right track, ensuring both sound deliver equal quality
      6 x USB 3.0/2.0 port(s) (4 at back panel, blue, 2 at mid-board)
      6 x USB 2.0/1.1 port(s) (4 at back panel, black, 2 at mid-board), 2 port(s) supports USB Over-Voltage Protection
      TUF ENGINE! Power Design :
      - 3 +2 Digital Phase Power Design
      - TUF Components (Choke, Cap. & MOSFET; certified by military-standard)
      - ASUS DIGI+ VRM Utility
      Ultimate COOL! Thermal Solution :
      - TUF Thermal Radar Core
      Safe & Stable! Guardian Angel :
      - TUF ESD Guards 2
      - TUF LANGuard
      - ASUS UEFI BIOS EZ Mode featuring friendly graphics user interface
      - USB 3.0 Boost
      - Disk Unlocker
      - ASUS O.C. Profile
      - ASUS EZ Flash 3
      - Multi-language BIOS
      ASUS Q-Design :
      - ASUS Q-Slot
      - ASUS Q-DIMM
      Windows® 7 , 32bit/64bit
      1 x PS/2 keyboard (purple)
      1 x PS/2 mouse (green)
      1 x DVI
      1 x D-Sub
      1 x LAN (RJ45) port(s)
      4 x USB 3.0 (blue)
      4 x USB 2.0
      3 x Audio jack(s)
      1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s) (19-pin, beige)
      1 x USB 2.0 connector(s) support(s) additional 2 USB 2.0 port(s)
      1 x COM port(s) connector(s)
      6 x SATA 6Gb/s connector(s)
      1 x CPU Fan connector(s) (1 x 4 -pin)
      2 x Chassis Fan connector(s) (2 x 4 -pin, [Black])
      1 x S/PDIF out header(s)
      1 x 8-pin ATX 12V Power connector(s)
      1 x System panel(s)
      1 x Chassis Intrusion connector(s)
      1 x DRCT header(s)
      1 x CPU OV
      1 x Clear CMOS jumper(s)
      1 x 14-1 pin TPM connector
      2 x SATA 6Gb/s cable(s)
      1 x TUF Certification card(s)
      1 x TUF 5 Year Warranty manual(s) (by region)
      1 x TUF Inside sticker(s)(white)
      128 Mb Flash ROM, UEFI AMI BIOS, PnP, DMI3.0, WfM2.0, SM BIOS 3.0, ACPI 5.0, Multi-language BIOS, ASUS EZ Flash 3, CrashFree BIOS 3, F11 EZ Tuning Wizard, F6 Qfan Control, F3 My Favorites, Quick Note, Last Modified log, F12 PrintScreen and ASUS DRAM SPD (Serial Presence Detect) memory information
      WfM 2.0, DMI 3.0, WOL by PME, PXE
      ASUS/TUF CPU-Z
      ATX Form Factor
      12 inch x 7.1 inch ( 30.5 cm x 19.8 cm )
    Similar Threads - TROOPER B150 Forum Date
    BIOS PC TROOPER B85 BIOS/UEFI Sep 17, 2015
    ASROCK B150A-X1 HYPER REV 1.01BOARDVIEW Schematics Feb 15, 2020
    Schematics PC GA-B150M-D3H DDR3 Schematics Aug 16, 2019
    Schematics PC GA-B150M-EVO Schematics Aug 16, 2019
    BIOS PC CF-G10-MX V20 B150M-K BIOS/UEFI Jul 2, 2019
    ASUS TROOPER B150 D3 Repair Guide
