TV SUPRA STV-LC16500WL
Discussion in 'ELECTRONIC DEVICE' started by technical, Sep 14, 2018.
    SUPRA LED
    Model: STV-LC16500WL
    Chassis/Version: TP.VST59.P67
    Panel: B156XTN03.2
    MainBoard: TP.VST59.P67
    IC MainBoard: CPU TSUMV59XE-Z1, Flash W25Q32FVSIG
    SUPRA STV-LC16500WL.
    Brand : AUO
    Model : B156XTN03.2 1 Compatible model
    Type : a-Si TFT-LCD, Panel
    Diagonal size : 15.6 inch
    Resolution : 1366x768, WXGA
    Display Mode : TN, Normally White, Transmissive
    Active Area : 344.232x193.536 mm
    Shape Style : Slim (PCBA Flat, Depth ?3.2mm)
    Surface : Glare (Haze 0%), Hard coating (3H)
    Brightness : 200 cd/m²
    Contrast Ratio : 500:1
    Display Colors : 262K (6-bit), CIE1931 45%
    Response Time : 2/6 (Tr/Td)
    Frequency : 60Hz
    Lamp Type : WLED Embedded (LED Driver)
    Signal Interface : LVDS (1 ch, 6-bit), 40 pins
    Voltage : 3.3V
    Similar Threads - SUPRA LC16500WL Forum Date
    TV KONKA LED32F3300C LED42F3300C KL26GT611 KL32GT615U SUPRA STV-LC22740WL STV-LC42740FL STV-LC26740WL S ELECTRONIC DEVICE Jun 1, 2019
    TV SUPRA STV-LC24T880WL - V1P12 ELECTRONIC DEVICE Oct 29, 2018
    TV SUPRA STV-LC24T850WL - V1N10 ELECTRONIC DEVICE Oct 29, 2018
    TV SUPRA STV-LC24T820FL - V2L12 ELECTRONIC DEVICE Oct 29, 2018
    TV SUPRA STV-LC24T810FL - T.MSD309.B61B ELECTRONIC DEVICE Oct 29, 2018
