SUPRA LED Model: STV-LC1637WL Chassis/Version: CV182L-A V2L06 Panel: B156HW02 V.5 Power Supply (PSU): Adapter 12V MainBoard: CV182L-A IC MainBoard: 751G6JB, 25Q32BVSIG, RT8284N, RT8295AH, YD1517P, SGM330A Тuner: CDT-3SP5I2-37 Brand : AUO Model : B156HW02 V5 20 Compatible model Type : a-Si TFT-LCD, Panel Diagonal size : 15.6 inch Resolution : 1920x1080, FHD Display Mode : TN, Normally White, Transmissive Active Area : 344.16x193.59 mm Shape Style : Wedge (PCBA Bent, Depth ?5.2mm) Surface : Glare (Haze 0%) Brightness : 300 cd/m² Contrast Ratio : 500:1 Display Colors : 262K (6-bit), CIE1931 60% Response Time : 8 (Tr+Td) Frequency : 60Hz Lamp Type : WLED Embedded (LED Driver) Signal Interface : LVDS (2 ch, 6-bit), 40 pins Voltage : 3.3V
