Lyra
Discussion in 'Computer Hardware Repair' started by technical, Jun 18, 2017.
    Lyra
    AC2200 Tri-Band Whole-Home Wi-Fi System Mesh Network – Seamless Coverage to Every Corner of Your Home, up to 6000 sq. ft
    P_setting_fff_1_90_end_500.png.
    • Banish Wi-Fi Dead Spots – Tri-band, tri-hub mesh-networking system delivers perfect Wi-Fi coverage to every corner of your home
    • Smart Antennas – Automatic optimization of hub connections ensures the fastest speeds, all the time
    • Smooth Connections, Always – Stay automatically connected to the best possible signal, wherever you are in the home
    • Commercial-grade Security – Protect all devices on your home network with ASUS AiProtection
    • You’re in Control – The ASUS Lyra app enables PC-free setup, network management and diagnostics, and notifies you about any problems
    • Family Overview – View and control each family member’s internet and app usage from your mobile device
    • Network Standard
      IEEE 802.11a, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IPv4, IPv6
    • Product Segment
      AC2200 ultimate AC performance : 400+867+867 Mbps
    • Coverage
      Very large homes
    • Data Rate
      802.11a : 6,9,12,18,24,36,48,54 Mbps
      802.11b : 1, 2, 5.5, 11 Mbps
      802.11g : 6,9,12,18,24,36,48,54 Mbps
      802.11n : up to 400 Mbps
      802.11ac : up to 867 Mbps
    • Antenna
      Internal antenna x 7
    • Transmit/Receive
      MIMO technology
      2.4 GHz 2 x 2
      5 GHz-1 2 x 2
      5 GHz-2 2 x 2
    • Operating Frequency
      2.4G Hz, 5 GHz-1, 5 GHz-2
    • Encryption
      WPA2-PSK
    • Ports
      RJ45 for 10/100/1000/Gigabits BaseT for WAN x 1, RJ45 for 10/100/1000/Gigabits BaseT for LAN x 1
    • Button
      Reset Button
    • Features
      MU-MIMO
      Adaptive QoS
      AiProtection
      Parental Control
      Guest Network :
    • Power Supply
      AC Input : 110V~240V(50~60Hz)
      DC Output : 12 V with max. 2 A current
    • OS Support
      Windows® 10
      Windows® 8.1
      Windows® 8
      Windows® 7
      Mac OS X 10.1
      Mac OS X 10.4
      Mac OS X 10.4
      Mac OS X 10.5
      Mac OS X 10.6
      Mac OS X 10.7
      Mac OS X 10.8
    • Dimensions
      149.8 x 149.8 x 49.5 ~ mm (LxWxH) (Without Bezel)
    • Package Content
      •Lyra x 3
      •AC adapter
      •Network cable (RJ-45)
      •Quick Start Guide
    ASUS
