LT41 SKL MB 14292-1
Discussion in 'LENOVO' started by manbook, Jun 19, 2019.
  1. manbook
    manbook Well-Known Member
    Good afternoon colleagues, such a laptop came in for repair, with a password in BIOS, platform LT41 SKL MB 14292-1 448-06701-0011 is still the same laptop from Lenovo Yoga, dropped the dump, saved it, no signal from yoga, back flooded no signal , it was all done on a beeprog programmer with a choice of w25q128bv chip with QE enabled and without it, all the same, I tried on another tl866 programmer with the latest software, also no signal, I thought the flash drive was dead, I ordered it twice, now I also install it signal ((
    It turns out or not properly preserved dump. There is an update - with a terra of offsite sent.
    Can anyone help me stick a fresh dump from a clean ME with a backup / I try it in parallel now, but so far there are no results.
    I tried different bios from Lenova, there is also no image on the screen.
    Similar Threads - LT41 14292 Forum Date
    Lenovo 300S LT41 SKL 14292-1 BIOS/UEFI Dec 30, 2015
    Lenovo S41-35 LT415-AMD 14882-1 BIOS/UEFI May 27, 2017
    LENOVO YOGA 500-14IHW 80N5 LT41 MB 14217-1M Schematics and BIOS BIOS/UEFI May 21, 2017
    LENOVO S41-75 S41-35 LT415-AMD MB 14235-1 BIOS/UEFI May 4, 2017
    Gateway LT41P - ZEA BIOS/UEFI Apr 27, 2016
    Build 14292.bin
    Programming it send Feedback result
  4. manbook
    I paid for vip, downloaded the firmware, flashed the microcircuit, everything is the same, there is a switch, there is a charge, but there is no image ((
  5. technical
    provided detail result compare
    old bios and bios send send, any other or same ?
  6. manbook
    It turned out to solve the problem, it turned out to be in the memory, it is necessary to install a new flash memory and program it with this config. thanks for bios build me region.bin
    ThienBui
      File size:
      135.6 KB
      6
