I. Installation and Operating Precautions To ensure safety and prevent possible damage to the rework station, it is required to install the rework station at a location complying with the following conditions. ◆ Away from inflammables. ◆ Free from splashing of water or other liquids. ◆ Free from the direct airflow impact from air conditioner, heater or ventilator. ◆ With good ventilation, dry location, free from excessive dust. ◆ Free from vibration or shock, at a stable and flat location. Power Supply Power and voltage should meet the following requirements: ◆ Use the power supply with little voltage fluctuation Voltage fluctuation: AC220V±10%。 Frequency fluctuation: 50/60Hz±0. 3% Space Requirements To facilitate operation, component replacement and maintenance for the rework station, it is required to reserve >300mm space at the back of the rework station.
Hello. Tell me, please, could you send me the exact settings for Bga Rework Station W-KIDI KID R600. The machine is, the guide and the drive is lost. If possible, please send, settings. Thank you in advance. I will be very grateful for the help.Please help solve the problem of professional settings.I can not accurately configure KID R600..KID R600 not properly remove the chip and not properly put in place
there is no temperature setting. http://thebgastore.com/manuals/R600manual.pdf Help set up all parameters of the machine. Thank you in advance. I will be very grateful for the help.
my friend, you once helped me find. I really ask you, help me find a file for usb flesh so that I can restore to the factory settingswe are both specialists, do a good deed to the Supreme. I will be very grateful to you my friendHelp me find a file to reset to factory settings. I beg you very much
