cpqtag write model "EliteBook 8560W" product number:cpqtag write SKU "XXXX" serial number:cpqtag write serial "XXXX" system board CT:cpqtag write sysbrdct "XXX" Usage: CPQTAG.EXE [CMD] [TYPE] {string} CMD = READ/WRITE/CHECK/MODIFY/GENERATE (REQUIRED) TYPE = SERIAL/ASSET/MODEL/ID/SKU/MBSN/TPM/SLP/FASTLOOK/DIGIPANELSUPPORT (REQUIRED) VPRO/WWAN/DEFAULTS/FLASHID/OWNER/CONFIGID/OSTYPE/ ATP/ME/COMPUTRACE/FNKEYSWITCH/PRODLINE/SYSBRDCT string = Data to write (optional for READ command) CPQTAG read serial CPQTAG write model M700 CPQTAG modify asset 6622HVS3P025 CPQTAG read TPM CPQTAG write TPM [ON,OFF] CPQTAG read SLP CPQTAG write SLP [ON,OFF] CPQTAG read VPRO [VPRO_STATE,DESCRIPTOR_STATE,MGMT_ENGINE_STATE,OVERRIDE_STATE] CPQTAG write VPRO [ON,OFF,LOCK,RESET] CPQTAG write ME [ON,OFF] CPQTAG write ME [LOCK | UNCOMMIT] CPQTAG read ME [STATUS] CPQTAG reboot [VPRO | ME] CPQTAG read WWAN CPQTAG write WWAN [ANTENNA] [NOANTENNA] CPQTAG write WWAN [GPS] [NOGPS] CPQTAG write WWAN [OP0,OP1,...OP7] CPQTAG write WWAN CLEAR CPQTAG write DEFAULTS CPQTAG read FLASHID (TT 1.0 systems only) CPQTAG write OWNER Hewlett-Pacakard Company CPQTAG write RESETKEYS ON CPQTAG write configid CPQTAG write PTDEFAULTS CPQTAG write MPM (Manufacturing Program Mode, formerly - FACTORYMODE CPQTAG read BraidWood CPQTAG write BraidWood [Default, Erase, Destroy, Create] CPQTAG write OsType CPQTAG write WWANWMI CPQTAG write VT CPQTAG write SOFTSTYLUS [SUPPORTED, NOTSUPPORTED] CPQTAG write ATP OFF CPQTAG read ATP CPQTAG write COMPUTRACE [ENABLE | DISABLE] (Write once/locked) CPQTAG write RESETWSD CPQTAG read FASTLOOK CPQTAG write FASTLOOK [ON,OFF] CPQTAG read DIGIPANELSUPPORT CPQTAG write DIGIPANELSUPPORT [ON,OFF] CPQTAG write FNKEYSWITCH [ENABLE | DISABLE] CPQTAG write ESTAR [ON,OFF] CPQTAG read OOCLVDS CPQTAG write OOCLVDS [DEFALUTTABLE|NULL|panel.txt] CPQTAG read | write PRODLINE CPQTAG read | write SYSBRDCT CPQTAG read | write FCM (FactoryControlMode) [0 - 7] You must reboot the system with 'CPQTAG reboot VPRO' after locking VPro configuration with one of: 'CPQTAG write VPRO [ON,OFF,LOCK,RESET]
