BIOS PC H170M-E D3
Discussion in 'BIOS/UEFI' started by technical, Oct 7, 2015.
    ASUS H170M-E D3
    BIOS H170M-E-D3-ASUS-0601 16MB
    Great-value micro-ATX H170 with 5X Protection II for dependable stability, DDR3/DDR3L memory compatibility, and UEFI BIOS with EZ Flash 3
    • 5X Protection II – Advanced hardware safeguards for all-round protection
    • DDR3/DDR3L memory compatibility
    • Lightning-fast M.2 with PCIe® 3.0 x4 interface
    • Epic gaming audio with noise-isolation design
    • Media-acclaimed UEFI BIOS with EZ Flash 3
    • Easy PC DIY with safe motherboard-mounting design
    • Fan Xpert 2+ advanced fan controls for ultimate cooling and silent performance
      Intel® for 6th Generation Core™ i7/Core™ i5/Core™ i3/Pentium®/Celeron® Processors
      Supports Intel® 14 nm CPU
      Supports Intel® Turbo Boost Technology 2.0
      * The Intel® Turbo Boost Technology 2.0 support depends on the CPU types.
      * Refer to www.asus.com for CPU support list
    • Chipset
      Intel® H170
      4 x DIMM, Max. 64GB, DDR3 1866(O.C.)/1600/1333 MHz Non-ECC, Un-buffered Memory
      Supports Intel® Extreme Memory Profile (XMP)
      * Hyper DIMM support is subject to the physical characteristics of individual CPUs.
      * Refer to www.asus.com for the Memory QVL (Qualified Vendors Lists).
      * The maximum memory frequency supported varies by processor.
      Integrated Graphics Processor- Intel® HD Graphics support
      Multi-VGA output support : HDMI/DVI-D/RGB ports
      - Supports HDMI with max. resolution 4096 x 2160 @ 24 Hz / 2560 x 1600 @ 60 Hz
      - Supports DVI-D with max. resolution 1920 x 1200 @ 60 Hz
      - Supports RGB with max. resolution 1920 x 1200 @ 60 Hz
      Maximum shared memory of 1024 MB
      Supports Intel® InTru™ 3D, Quick Sync Video, Clear Video HD Technology, Insider™
      Supports up to 3 displays simultaneously
    • Multi-GPU Support
      Supports AMD 2-Way CrossFireX Technology
      1 x PCIe 3.0/2.0 x1 (x16 mode, gray)
      1 x PCIe 3.0/2.0 x1 (max at x4 mode, black)
      1 x PCIe 3.0/2.0 x1
      1 x PCI
      Intel® H170 chipset :
      4 x SATA 6Gb/s port(s), gray,
      1 x M.2 Socket 3, with M key, type 2242/2260/2280 storage devices support (both SATA & PCIE mode)
      Support Raid 0, 1, 5, 10
      Supports Intel® Smart Response Technology
      Realtek® RTL8111H, 1 x Gigabit LAN Controller(s)
      Realtek® ALC887-VD2 8-Channel High Definition Audio CODEC *2
      - Supports : Jack-detection, Front Panel Jack-retasking
      Audio Feature :
      - Audio Shielding: Ensures precision analog/digital separation and greatly reduced multi-lateral interference
      - Dedicated audio PCB layers: Separate layers for left and right channels to guard the quality of the sensitive audio signals
      - Premium Japanese-made audio capacitors: Provide warm, natural and immersive sound with exceptional clarity and fidelity
      8 x USB 3.0/2.0 port(s)
      6 x USB 2.0/1.1 port(s)
      ASUS EPU :
      - EPU
      - GPU Boost *3
      - Anti-Surge
      - Low EMI Solution
      - USB 3.0 Boost
      - Mobo Connect
      - PC Cleaner
      ASUS Quiet Thermal Solution :
      - Stylish Fanless Design Heat-sink solution
      - ASUS Fan Xpert 2+
      - ASUS EZ Flash 3
      - ASUS UEFI BIOS EZ Mode
      - Push Notice
      ASUS Q-Design :
      - ASUS Q-Slot
      - ASUS Q-DIMM
      Media Streamer
      Windows® 7 , 32bit/64bit *3
      1 x PS/2 keyboard (purple)
      1 x PS/2 mouse (green)
      1 x DVI-D
      1 x D-Sub
      1 x LAN (RJ45) port(s)
      4 x USB 3.0 (blue)
      2 x USB 2.0
      3 x Audio jack(s)
      2 x USB 3.0 connector(s) support(s) additional 4 USB 3.0 port(s) (19-pin, blue)
      2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
      1 x M.2 Socket 3 for M Key, type 2242/2260/2280 devices
      1 x LPT header
      1 x COM port(s) connector(s)
      4 x SATA 6Gb/s connector(s)
      1 x CPU Fan connector(s) (1 x 4 -pin)
      2 x Chassis Fan connector(s) (2 x 4 -pin)
      1 x S/PDIF out header(s)
      1 x 8-pin ATX 12V Power connector(s)
      1 x System panel(s)
      1 x Clear CMOS jumper(s)
      1 x 14-1 pin TPM connector
      2 x SATA 6Gb/s cable(s)
      1 x M.2 Screw Package
      1 x Supporting DVD
      128 Mb Flash ROM, UEFI AMI BIOS, PnP, DMI3.0, WfM2.0, SM BIOS 3.0 ACPI 5.0, Multi-language BIOS,
      ASUS EZ Flash 3, CrashFree BIOS 3, F11 EZ Tuning Wizard, F6 Qfan Control, F3 My Favorites, Quick Note, Last Modified log, F12 PrintScreen, and ASUS DRAM SPD (Serial Presence Detect) memory information
      WfM 2.0, DMI 3.0, WOL by PME, PXE
      ASUS EZ Update
      uATX Form Factor
      9.6 inch x 8.8 inch ( 24.4 cm x 22.4 cm )
      *1: These functions will work depending on the CPU installed.
      *2: Use a chassis with HD audio module in the front panel to support an 8-channel audio output.
      *3: The function supported varies by processor.
      *4: Please refer to ASUS website and download “Windows® 7 installation guide” and “ASUS EZ installer” to install Windows® 7.
    Similar Threads - H170M Forum Date
    Schematics PC GA-H170M-D3HP Schematics Mar 21, 2018
    Schematics PC GA-H170M-DS3H Schematics Mar 16, 2018
    Schematics PC GA-H170M-HD3 DDR3-1.0 BV Schematics Mar 16, 2018
    Schematics PC ASROCK H170M PRO4 R1.02 (70-MXGZL0-A11).fz Schematics Feb 25, 2018
    Schematics PC ASROCK H170M PRO4S R1.02 (70-MXGZW0-A01).fz Schematics Feb 25, 2018
