BIOS PC H170I-PLUS D3
    H170I-PLUS D3
    BIOS H170I-PLUS-D3-ASUS-0403 16MB
    Supreme mini-ITX H170 with onboard 802.11ac Wi-Fi, M.2 transfer, and 5X Protection II for dependable stability
    • 5X Protection II – Advanced hardware safeguards for all-round protection
    • DDR3/DDR3L memory compatibility
    • 2x2 Dual-Band 802.11ac + BT4.0 connectivity
    • Media-acclaimed UEFI BIOS with EZ Flash 3
    • Fan Xpert 2+ advanced fan controls for ultimate cooling and silent performance
    • Lightning-fast M.2 with PCIe® 3.0 x4 interface
      Intel® for 6th Generation Core™ i7/Core™ i5/Core™ i3/Pentium®/Celeron® Processors
      Supports Intel® 14 nm CPU
      Supports Intel® Turbo Boost Technology 2.0
      * The Intel® Turbo Boost Technology 2.0 support depends on the CPU types.
    • Chipset
      Intel® H170
      2 x DIMM, Max. 32GB, DDR3 1866(O.C.)/1600/1333 MHz Non-ECC, Un-buffered Memory
      Supports Intel® Extreme Memory Profile (XMP)
      * Hyper DIMM support is subject to the physical characteristics of individual CPUs.
      * To prevent system instability, either install DDR3L DIMMs or DDR3 DIMMs with voltage lower than 1.5V.
      Integrated Graphics Processor- Intel® HD Graphics support
      Multi-VGA output support : HDMI/DVI-D/RGB/DisplayPort ports
      - Supports HDMI with max. resolution 4096 x 2160 @ 24 Hz / 2560 x 1600 @ 60 Hz
      - Supports DVI-D with max. resolution 1920 x 1200 @ 60 Hz
      - Supports RGB with max. resolution 1920 x 1200 @ 60 Hz
      - Supports DisplayPort with max. resolution 4096 x 2304 @ 60 Hz
      Maximum shared memory of 1024 MB
      Supports Intel® InTru™ 3D, Quick Sync Video, Clear Video HD Technology, Insider™
      Supports up to 3 displays simultaneously
      1 x PCIe 3.0/2.0 x16
      Intel® H170 chipset :
      1 x SATA Express port, Compatible with 2 x SATA 6.0 Gb/s ports
      1 x M.2 Socket 3, with M key, type 2242/2260/2280 storage devices support (both SATA & PCIE mode)
      4 x SATA 6Gb/s port(s)
      Intel® I219V, 1 x Gigabit LAN Controller(s)
    • Wireless Data Network
      Wi-Fi 802.11 a/b/g/n/ac
      Supports dual band frequency 2.4/5 GHz
      Support ASUS Wi-Fi Go! Utility
    • Bluetooth
      Bluetooth V4.0
      Realtek® ALC887 7.1-Channel High Definition Audio CODEC *1
      - Supports : Jack-detection, Front Panel Jack-retasking
      8 x USB 3.0/2.0 port(s) (6 at back panel, blue, 2 at mid-board)
      4 x USB 2.0/1.1 port(s) (4 at mid-board)
      ASUS 5X Protection II :
      - ASUS LANGuard - 2.5X higher surge tolerance
      - ASUS Overvoltage Protection - World-class circuit-protecting power design
      - ASUS DIGI+ VRM - 6 Phase digital power design
      - ASUS DRAM Overcurrent Protection - Prevents damage from short circuits
      - ASUS Stainless-Steel Back I/O - 3X corrosion-resistance for greater durability
      - ASUS ESD Guards - Electrostatic discharge protection
      ASUS EPU :
      - Anti-Surge
      - USB 3.0 Boost
      - Disk Unlocker
      ASUS Quiet Thermal Solution :
      - Stylish Fanless Design Heat-sink solution
      - ASUS Fan Xpert 2+
      - ASUS EZ Flash 3
      - ASUS UEFI BIOS EZ Mode
      - Push Notice
      ASUS Q-Design :
      - ASUS Q-DIMM
      Media Streamer
      Windows® 7 , 32bit/64bit *2
      1 x PS/2 keyboard/mouse combo port(s)
      1 x DVI-D
      1 x D-Sub
      1 x DisplayPort
      1 x LAN (RJ45) port(s)
      6 x USB 3.0 (blue)
      1 x Optical S/PDIF out
      3 x Audio jack(s)
      1 x ASUS Wi-Fi GO! module (Wi-Fi 802.11 a/b/g/n/ac and Bluetooth v4.0
      1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s) (19-pin, blue)
      2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
      1 x SATA Express connector: , Compatible with 2 x SATA 6.0 Gb/s ports
      1 x M.2 Socket 3 with M Key design, type 2242/2260/2280/22110 storage devices support (Supports both SATA & PCIE SSD)
      1 x COM port(s) connector(s)
      4 x SATA 6Gb/s connector(s)
      1 x CPU Fan connector(s) (1 x 4 -pin)
      2 x Chassis Fan connector(s) (2 x 4 -pin)
      1 x 4-pin ATX 12V Power connector(s)
      1 x Internal speaker connector(s)
      1 x System panel(s)
      1 x Clear CMOS jumper(s)
      1 x 14-1 pin TPM connector
      2 x SATA 6Gb/s cable(s)
      1 x Supporting DVD
      1 x ASUS 2T2R dual band Wi-Fi moving antennas (Wi-Fi 802.11a/b/g/n/ac compliant)
      128 Mb Flash ROM, UEFI AMI BIOS, PnP, DMI3.0, WfM2.0, SM BIOS 3.0 ACPI 5.0, Multi-language BIOS,
      ASUS EZ Flash 3, CrashFree BIOS 3, F6 Qfan Control, F3 My Favorites, Quick Note, Last Modified log, F12 PrintScreen, and ASUS DRAM SPD (Serial Presence Detect) memory information
      WfM 2.0, DMI 3.0, WOL by PME, PXE
      ASUS EZ Update
      Mini ITX Form Factor
      6.7 inch x 6.7 inch ( 17 cm x 17 cm )
      *1: Use a chassis with HD audio module in the front panel to support an 8-channel audio output.
      *2: Please refer to ASUS website and download “Windows® 7 installation guide” and “ASUS EZ installer” to install Windows® 7.
    #1 technical, Sep 16, 2015
    Similar Threads - H170I PLUS Forum Date
    BIOS PC ASUS H170I-PRO BIOS/UEFI Aug 20, 2016
    Schematics PC ASUS M2N68-AM PLUS Schematics Aug 17, 2019
    Samsung 2232 BW Plus ELECTRONIC DEVICE Jul 11, 2019
    BIOS PC MSI H110M PRO-VH PLUS MS-7A15 BIOS/UEFI Jun 5, 2019
    Asus H170I-PLUS-D3 RG
