BIOS PC H170-PLUS D3
Discussion in 'BIOS/UEFI' started by technical, Oct 7, 2015.
    ASUS H170-PLUS D3
    BIOS H170-PLUS-D3-ASUS-0404 16MB
    Full-featured ATX H170 with 5X Protection II for dependable stability, DDR3/DDR3L memory compatibility, and UEFI BIOS with EZ Flash 3
    • 5X Protection II – Advanced hardware safeguards for all-round protection
    • DDR3/DDR3L memory compatibility
    • Lightning-fast M.2 with PCIe® 3.0 x4 interface
    • Epic gaming audio with noise-isolation design
    • Media-acclaimed UEFI BIOS with EZ Flash 3
    • Easy PC DIY with safe motherboard-mounting design
    • Fan Xpert 2+ advanced fan controls for ultimate cooling and silent performance
      Intel® Socket 1151 for 6th Generation Core™ i7/Core™ i5/Core™ i3/Pentium®/Celeron® Processors
      Supports Intel® 14 nm CPU
      Supports Intel® Turbo Boost Technology 2.0
      * The Intel® Turbo Boost Technology 2.0 support depends on the CPU types.
    • Chipset
      Intel® H170
      4 x DIMM, Max. 64GB, DDR3 1866(O.C.)/1600/1333 MHz Non-ECC, Un-buffered Memory
      Dual Channel Memory Architecture
      Supports Intel® Extreme Memory Profile (XMP)
      * Hyper DIMM support is subject to the physical characteristics of individual CPUs.
      * The maximum memory frequency supported varies by processor.
      Integrated Graphics Processor- Intel® HD Graphics support
      Multi-VGA output support : HDMI/DVI-D/RGB ports
      - Supports HDMI with max. resolution 4096 x 2160 @ 24 Hz / 2560 x 1600 @ 60 Hz
      - Supports DVI-D with max. resolution 1920 x 1200 @ 60 Hz
      - Supports RGB with max. resolution 1920 x 1200 @ 60 Hz
      Maximum shared memory of 1024 MB
      Supports Intel® InTru™ 3D, Quick Sync Video, Clear Video HD Technology, Insider™
      Supports up to 3 displays simultaneously
    • Multi-GPU Support
      Supports AMD Quad-GPU CrossFireX™ Technology
      1 x PCIe 3.0/2.0 x16 (x16 mode, gray)
      1 x PCIe 3.0/2.0 x16 (max at x4 mode, black)
      2 x PCIe 3.0/2.0 x1
      2 x PCI
      Intel® H170 chipset :
      1 x M.2 Socket 3, , with M key, type 2242/2260/2280 storage devices support (both SATA & PCIE mode)
      4 x SATA 6Gb/s port(s), gray,
      Support Raid 0, 1, 5, 10
      Supports Intel® Smart Response Technology*1
      Realtek® RTL8111H, 1 x Gigabit LAN Controller(s)
      Realtek® ALC887 8-Channel High Definition Audio CODEC *2
      - Supports : Jack-detection, Front Panel Jack-retasking
      Audio Feature :
      - Audio Shielding: Ensures precision analog/digital separation and greatly reduced multi-lateral interference
      - Dedicated audio PCB layers: Separate layers for left and right channels to guard the quality of the sensitive audio signals
      - Premium Japanese-made audio capacitors: Provide warm, natural and immersive sound with exceptional clarity and fidelity
      8 x USB 3.0/2.0 port(s) (4 at back panel, blue, 4 at mid-board)
      6 x USB 2.0/1.1 port(s) (2 at back panel, black, 4 at mid-board)
      ASUS 5X Protection II :
      - ASUS LANGuard - 2.5X higher surge tolerance
      - ASUS Overvoltage Protection - World-class circuit-protecting power design
      - ASUS DIGI+ VRM - 7 Phase digital power design
      - ASUS DRAM Overcurrent Protection - Prevents damage from short circuits
      - ASUS Stainless-Steel Back I/O - 3X corrosion-resistance for greater durability
      ASUS EPU :
      - EPU
      - GPU Boost *3
      - Anti-Surge
      - Low EMI Solution
      - USB 3.0 Boost
      - Disk Unlocker
      - Mobo Connect
      - PC Cleaner
      ASUS Quiet Thermal Solution :
      - Stylish Fanless Design Heat-sink solution & MOS Heatsink
      - ASUS Fan Xpert 2+
      - ASUS EZ Flash 3
      - ASUS UEFI BIOS EZ Mode
      - Push Notice
      ASUS Q-Design :
      - ASUS Q-Slot
      Media Streamer
      Windows® 7 , 32bit/64bit *3
      1 x PS/2 keyboard (purple)
      1 x PS/2 mouse (green)
      1 x DVI-D
      1 x D-Sub
      1 x LAN (RJ45) port(s)
      4 x USB 3.0 (blue) Type-A
      2 x USB 2.0
      3 x Audio jack(s)
      2 x USB 3.0 connector(s) support(s) additional 4 USB 3.0 port(s) (19-pin)
      2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
      1 x M.2 Socket 3 for M Key, type 2242/2260/2280 devices
      1 x COM port(s) connector(s)
      4 x SATA 6Gb/s connector(s)
      1 x CPU Fan connector(s) (1 x 4 -pin)
      2 x Chassis Fan connector(s) (2 x 4 -pin)
      1 x S/PDIF out header(s)
      1 x 8-pin ATX 12V Power connector(s)
      1 x System panel(s)
      1 x Clear CMOS jumper(s)
      2 x SATA 6Gb/s cable(s)
      1 x M.2 Screw Package
      1 x Supporting DVD
      128 Mb Flash ROM, UEFI AMI BIOS, PnP, DMI3.0, WfM2.0, SM BIOS 3.0 ACPI 5.0, Multi-language BIOS,
      ASUS EZ Flash 3, CrashFree BIOS 3, F11 EZ Tuning Wizard, F6 Qfan Control, F3 My Favorites, Quick Note, Last Modified log, F12 PrintScreen, and ASUS DRAM SPD (Serial Presence Detect) memory information
      WfM 2.0, DMI 3.0, WOL by PME, PXE
      ASUS EZ Update
      ATX Form Factor
      12 inch x 8.6 inch ( 30.5 cm x 21.8 cm )
      *1: These functions will work depending on the CPU installed.
      *2: Use a chassis with HD audio module in the front panel to support an 8-channel audio output.
      *3: The function supported varies by processor.
      *4:Please refer to ASUS website and download “Windows® 7 installation guide” and “ASUS EZ installer” to install Windows® 7.
    Similar Threads - H170 PLUS Forum Date
    XPC cube SH170R6 PLUS BIOS/UEFI May 31, 2016
    BIOS PC H170M-PLUS BIOS/UEFI Sep 16, 2015
    BIOS PC H170I-PLUS D3 BIOS/UEFI Sep 16, 2015
    Schematics PC GA-H170-Gaming 3 DDR3 Schematics Mar 31, 2018
    Schematics PC GA-H170-D3H Schematics Mar 31, 2018
    ASUS H170-PLUS D3 Repair Guide
