GA-MA790FX-DQ6 (rev. 1.0) AMD 790FX + SB600 Chipset BIOS MA79XDQ6.F7g Supports AMD Phenom™ / Athlon™ series processors Dual Channel DDR2 1066* memory support for remarkable system performance Quad PCI-E 2.0 x16 graphics interfaces with ATI CrossFireX™ support for extreme gaming performance Integrated SATA 3Gb/s with RAID function and IEEE 1394a connection Integrated dual LAN with Teaming function to provide twice bandwidth of transmission speed High quality 8-ch ALC889A High Definition audio with DTS Connect support, featuring 106dB Signal to Noise Ratio and Full Rate Lossless Audio with Blu-ray/ HD DVD playback support. Ultra Durable 2 motherboard features High Quality CPU Power design with Ferrite core chokes, Low RDS (on) MOSFET and Solid Capacitors. Durable Capacitors that take advantage of Japanese manufactured SMD (Surface Mount Device) Solid Capacitors for enhanced system durability. Re-engineered Thermal Design featuring All Copper Silent-Pipe and Crazy Cool External SATA2 design makes you enjoying "easy to use, easy to go, and easy to play" * DDR2 1066 is supported with combination of AM2+ processors and DDR2 1066 memory modules, please refer "Memory Support List" for detail memory support information.
