BIOS PC Foxconn G41MD BIOS
Discussion in 'BIOS/UEFI' started by technical, Sep 23, 2016.
    Foxconn G41MD
    BIOS A81F1P06
    • Intel® Core™2 Quad, Core™2 Duo, Pentium® Dual-Core ,Celeron®processors, Socket T (LGA775) Supports Intel® 45nm Multi-Core processors
    • 1333/1066/800/533 MHz (FSB)
    • Dual channel DDR3 1333(oc)/1066/800/MHz, 2 DIMMs, Max 8GB
    • 1* PCIe x16, 2* PCI
    • 3*SATAII ,1*ATA100
    • 5.1 channel by Realtek IC, Gigabit LAN by Atheros IC
    • 8 USB 2.0 ports
    Note: 1. If you use the FSB533 CPU, you should short the CPU_533 jumper pin1&Pin2
    2. If you use the CPU is not FSB533, you should short the CPU_533 jumper pin2&Pin3
    Similar Threads - Foxconn G41MD BIOS Forum Date
    BIOS PC Foxconn G41MD-V BIOS BIOS/UEFI Sep 23, 2016
    Schematics PC Foxconn A76GMV Schematics Aug 6, 2019
    BIOS PC FOXCONN H55M01S1 25Q16BVS BIOS/UEFI Aug 6, 2019
    BIOS PC mình cần bios foxconn h55m01s1-s BIOS/UEFI Aug 6, 2019
    Schematics PC FOXCONN S04-915S04-MAINBOARD-A-HW-SCH-061404 Schematics Apr 14, 2019
