AX168 uma enable not fuction
Discussion in 'Computer Hardware Repair' started by synapsea, Jan 3, 2017.
  1. synapsea
    synapsea Well-Known Member
    Similar Threads - AX168 enable fuction Forum Date
    HP-Compaq Compaq CQ42-257TU AX168 BIOS/UEFI Oct 17, 2014
    LA-5891P UMA ENABLE PROBLEM Computer Hardware Repair Mar 24, 2017
    UMA enable DV6-6c52el Computer Hardware Repair Jan 24, 2017
    How to enable Anywhere in macOS Sierra Apple - macOS Sep 27, 2016
    What replaces ?
  4. synapsea
    I bought guide of uma enable , on it are pictures with what need to replace for Ax1 hp.
    I followed everything as in the picture but no screen .
    Inviato dal mio SM-N910H utilizzando Tapatalk
  5. technical
    AX1 or AX168 ?
    send me pictures you have converted positions
    by@vinafix.vn
  6. synapsea
    Ok i will send you pictures tonight
  7. synapsea
    20170105_090409. Work perfect i make i mistake on pc133 but all work perfect . You are the best
  8. synapsea
    Today i tried same method like AX138 on AX1J (DAAX1JMB8CO) in this case removed R383 .
    Work perfectly .
    i will upload pictures .
  9. technical
    AX1J CPU is onboard ?
  10. synapsea
    Yes Cpu onboard . Screenshot_2017-01-06-09-49-49.
  11. synapsea
    Screenshot_2017-01-06-09-53-34.
  12. synapsea
    Only one problem now cpu temperature is to high 78°C and fan is spinig max. Any suggestion
  13. synapsea
    20170106_105140.
  14. technical
    100% is problematic.
    78% not really matter.
    take a long treadmill test to see if there are any errors arising.
  15. nazrul1450
    nazrul1450 New Member
    hi admin.. can i download all resources if i purchase super vip membership? or tell me difference between business plan and super vip.
  16. technical
    Hello
    Super vip's personal account received only one user.
    Business accounts for multiple users at your store.
    * All VIP no downloads resources/ebook.
  17. synapsea
    solved my mistake for the FAN is Bios i flashed wiith another bios for ax1 uma.
    now flashed with original bios and work perfectly..
  18. 03ifix
    03ifix Moderator
    hi admin i need help.
  19. technical
    now error what ?
  20. 03ifix
    03ifix Moderator
    sorry my shop is closing time we will talk satuarday thanx .
  21. kushal
    kushal New Member
    hi,
    i hv bought your guide for ax1j non graphic conversion ....i hv done that mentioned in that guide , but no success it still working on amd graphics ..not on intel..
    need ur help urgently
