ASUS X556UR
Discussion in 'BIOS/UEFI' started by technical, Aug 22, 2016.
    ASUS X556UR
    CPU 6th
    BIOS
    • Processor
      Intel® Core™ i7 7500U/6500U Processor,
      Intel® Core™ i5 7200U/6200U Processor,
      Intel® Core™ i3 7100U/6100U Processor,
    • Operating System
      Windows 10 Home
      Windows 10 Pro
      DDR4 2133MHz SDRAM, 1 x SO-DIMM socket for expansion, up to 12 GB SDRAM
    • Display
      15.6" (16:9) LED backlit HD (1366x768) Glare Panel with 45% NTSC
      15.6" (16:9) LED backlit HD (1366x768) Anit-Glaire Panel with 45% NTSC
      15.6" (16:9) LED backlit FHD (1920x1080) Anit-Glaire Panel with 45% NTSC
      NVIDIA GeForce 930MX , with 2GB VRAM
      Hard Drives:
      500GB/1TB 5400RPM SATA HDD
      2TB 5400RPM SATA HDD
      500GB/750GB/1TB 7200RPM SATA HDD
      Solid State Drives:
      128GB/256GB SATA3 SSD
    • Optical Drive
      Super-Multi DVD
    • Keyboard
      Chicklet keyboard with isolated Num key
    • Card Reader
      Multi-format card reader (SD/SDHC/SDXC)
    • WebCam
      VGA Web Camera
    • Networking
      Wi-Fi
      Integrated 802.11b/g/n
      10/100/1000 Base T
      Bluetooth
      Built-in Bluetooth V4.0 (Optional)
    • Interface
      1 x COMBO audio jack
      1 x VGA port/Mini D-sub 15-pin for external monitor
      1 x USB 3.0 port(s)
      1 x USB 2.0 port(s)
      1 x USB-C Gen 1 (up to 5 Gbps)
      1 x RJ45 LAN Jack for LAN insert
      ASUS SonicMaster Technology
    • Battery
      2 Cells 38 Whrs Polymer Battery
    • Power Adapter
      Plug Type :ø4 (mm)
      Output :
      19 V DC, 3.42 A, 65 W
      Input :
      100 -240 V AC, 50/60 Hz universal
      3/ 2 pin compact power supply system
    • Dimensions
      38.2 x 25.8 x 2.55 cm (WxDxH)
    • Weight
      2.3 kg (with 2 cell battery) with Battery
    • Security
      Kensington lock
      BIOS Booting User Password Protection
      HDD User Password Protection and Security
    • Manufacturer Warranty
      1-year limited International hardware warranty. *different by country
    Similar Threads - ASUS X556UR Forum Date
    ASUS board number X556UV_MB REV3.1 sticker model X556URK BIOS/UEFI Jul 4, 2019
    ASUS Vivobook X556URK BIOS BIOS/UEFI Jul 30, 2017
    ASUS Vivobook X556UR BIOS/UEFI May 21, 2017
