BIOS PC ASUS Q170M2
Discussion in 'BIOS/UEFI' started by technical, Sep 5, 2016.
    ASUS Q170M2
    BIOS Q170M2-SI-1802
      Intel® for 6th Generation Core™ i7/Core™ i5/Core™ i3/Pentium®/Celeron® Processors
      Supports Intel® 14 nm CPU
      Supports Intel® Turbo Boost Technology 2.0
      * The Intel® Turbo Boost Technology 2.0 support depends on the CPU types.
      * Refer to www.asus.com for CPU support list
    • Chipset
      Intel® Q170
      4 x DIMM, Max. 64GB, DDR4 2133 MHz Non-ECC, Un-buffered Memory
      Supports Intel® Extreme Memory Profile (XMP)
      * Hyper DIMM support is subject to the physical characteristics of individual CPUs.
      * Refer to www.asus.com for the Memory QVL (Qualified Vendors Lists).
      * The maximum memory frequency supported varies by processor.
      * To prevent system instability, either install DDR3L DIMMs or DDR3 DIMMs with voltage lower than 1.5V.
      Integrated Graphics Processor- Intel® HD Graphics support
      Multi-VGA output support : DVI-D/DVI-I/DisplayPort ports
      - Supports DVI-D with max. resolution 1920 x 1200 @ 60 Hz
      - Supports DVI-I with max. resolution 1920 x 1200 @ 60 Hz
      - Supports DisplayPort with max. resolution 4096 x 2304 @ 60 Hz
      Maximum shared memory of 1024 MB
      Supports Intel® InTru™ 3D, Quick Sync Video, Clear Video HD Technology, Insider™
      Supports up to 3 displays simultaneously
    • Multi-GPU Support
      Supports AMD Quad-GPU CrossFireX™ Technology
      1 x PCIe 3.0/2.0 x16 (x16 mode)
      1 x PCIe 3.0/2.0 x16 (x8 mode)
      1 x PCIe 3.0/2.0 x1
      1 x PCI
      1 x mini-PCIe (half-length)
      Intel® Q170 chipset :
      6 x SATA 6Gb/s port(s),
      1 x M.2 Socket 3, with M key, type 2242/2260/2280 storage devices support (both SATA & PCIE mode)*
      Intel® I219LM, 1 x Gigabit LAN Controller(s)
      Realtek® RTL8111H, 1 x Gigabit LAN Controller(s)
      ASUS LAN Guard
      Realtek® ALC887 7.1-Channel High Definition Audio CODEC *1
      - Supports : Jack-detection, Front Panel Jack-retasking
      10 x USB 3.0/2.0 port(s) (6 at back panel, blue, 4 at mid-board)
      2 x USB 2.0/1.1 port(s) (2 at mid-board)
      ASUS 5X Protection II :
      - ASUS LANGuard - 2.5X higher surge tolerance
      - ASUS Overvoltage Protection - World-class circuit-protecting power design
      - ASUS DIGI+ VRM - 5 Phase digital power design
      - ASUS DRAM Overcurrent Protection - Prevents damage from short circuits
      - ASUS Stainless-Steel Back I/O - 3X corrosion-resistance for greater durability
      - Mobo Connect
      ASUS Quiet Thermal Solution :
      - ASUS Fan Xpert 2+
      - ASUS EZ Flash 3
      - ASUS UEFI BIOS EZ Mode
      - Push Notice
      ASUS Q-Design :
      - ASUS Q-Slot
      - ASUS Q-DIMM
      TPM IC Onboard
      Media Streamer
      Windows® 7 , 32bit/64bit *2
      1 x PS/2 keyboard (purple)
      1 x PS/2 mouse (green)
      1 x DVI-D
      1 x DVI-I
      1 x DisplayPort
      2 x LAN (RJ45) port(s)
      6 x USB 3.0 (blue)
      3 x Audio jack(s)
      1 x MONO out header *3
      2 x USB 3.0 connector(s) support(s) additional 4 USB 3.0 port(s)
      1 x USB 2.0 connector(s) support(s) additional 2 USB 2.0 port(s)
      1 x M.2 Socket 1 with E key, type 2230 Wi-Fi devices support
      1 x M.2 Socket 3 with M Key design, type 2242/2260/2280 storage devices support (Supports both SATA & PCIE SSD)
      1 x LPT header
      2 x COM port(s) connector(s)
      6 x SATA 6Gb/s connector(s)
      1 x CPU Fan connector(s) (1 x 4 -pin)
      2 x Chassis Fan connector(s) (2 x 4 -pin)
      1 x 8-pin ATX 12V Power connector(s)
      1 x Internal speaker connector(s)
      1 x System panel(s)
      1 x Chassis Intrusion connector(s)
      2 x SATA 6Gb/s cable(s)
      2 x M.2 Screw Package
      1 x Supporting DVD
      128 Mb Flash ROM, UEFI AMI BIOS, PnP, DMI3.0, WfM2.0, SM BIOS 3.0 ACPI 5.0, Multi-language BIOS,
      ASUS EZ Flash 3, CrashFree BIOS 3, F6 Qfan Control, F3 My Favorites, Quick Note, Last Modified log, F12 PrintScreen, and ASUS DRAM SPD (Serial Presence Detect) memory information
      WfM 2.0, DMI 3.0, WOL by PME, PXE
      ASUS EZ Update
      uATX Form Factor
      9.6 inch x 9.6 inch ( 24.4 cm x 24.4 cm )
      *: M.2 shares SATA mode with SATA ports. Change this item before installing M.2 SATA devices.
      *1: Use a chassis with HD audio module in the front panel to support an 8-channel audio output.
      *2 Please refer to ASUS website and download “Windows® 7 installation guide” and “ASUS EZ installer” to install Windows® 7.
      *3: Use with amplified speaker is suggested.
      P_setting_fff_1_90_end_500.png.
    Similar Threads - ASUS Q170M2 Forum Date
    ASUS X411UA Schematic Schematics Apr 22, 2020
