ASUS P10S WS BIOS Version: 0704 CPU Build in Intel® Socket 1151 Core™ i7/Core™ i5/Core™ i3/for Xeon® E3-1200 v5 and 6th genereation CoreTM, Pentium® and Celeron® Processors Supports Intel® 14 nm CPU Supports Intel® Turbo Boost Technology * Refer to www.asus.com for CPU support list Chipset Build in Intel® C236 Memory 4 x DIMM, Max. 64GB, DDR4 2133 MHz ECC, Non-ECC, Un-buffered Memory Dual Channel Memory Architecture * Refer to www.asus.com for the Memory QVL (Qualified Vendors Lists). Graphic Integrated Graphics Processor Multi-VGA output support : HDMI/DVI-D/DisplayPort ports VGA port - Supports VGA with max. resolution 1920 x 1200 @ 60 Hz - Supports HDMI with max. resolution 4096 x 2160 @ 60 Hz / 4096 x 2160 @ 24 Hz - Supports DVI-D with max. resolution 1920 x 1200 @ 60 Hz - Supports DisplayPort with max. resolution 4096 x 2304 @ 60 Hz Maximum shared memory of 512 MB Supports Intel® HD Graphics, InTru™ 3D, Quick Sync Video, Clear Video HD Technology, Insider™ Multi-GPU Support Supports AMD Quad-GPU CrossFireX™ Technology Expansion Slots 1 x PCIe 3.0/2.0 x16 (x16/x8) 1 x PCIe 3.0/2.0 x16 (x8 mode) *1 1 x PCIe 3.0/2.0 x16 (x4 mode) *2 1 x PCIe 3.0/2.0 x16 (x4 mode) *2 Storage Intel® C236 Chipset : 8 x SATA 6Gb/s port(s), 2 x M.2 Socket 3*3, with M Key, type 2242/2260/2280/22110 storage devices support (both SATA & PCIE mode) Support Raid 0, 1, 5, 10 Intel® Rapid Storage Technology Enterprise supports LAN Intel® I210, 2 x Gigabit LAN Controller(s) Support Teaming Technology Audio Realtek® ALC1150 8-Channel High Definition Audio CODEC - Supports : Jack-detection, Multi-streaming, Front Panel MIC Jack-retasking - High quality 112 dB SNR stereo playback output (Line-out at rear) and 104 dB SNR recording input (Line-in) Audio Feature : - Absolute Pitch 192kHz/ 24-bit True BD Lossless Sound - DTS Connect - DTS Studio Sound - Optical S/PDIF out port(s) at back panel - BD Audio Layer Content Protection - Audio Shielding: Ensures precision analog/digital separation and greatly reduced multi-lateral interference - Audio amplifier: Provides the highest-quality sound for headphone and speakers - Premium Japanese-made audio capacitors: Provide warm, natural and immersive sound with exceptional clarity and fidelity - Top notch audio sensation delivers according to the audio configuration Separate layer for left and right track, ensuring both sound deliver equal quality USB Ports Built-in Controller : 4 x USB 2.0 port(s) (Type-A, 4 at mid-board) Built-in Controller : *4 6 x USB 3.0 port(s) (4 at back panel, , Type-A) Built-in Controller : 2 x USB 3.1 port(s) (2 at back panel, , Type-A + Type-C) Special Features ASUS EPU : - EPU ASUS Digital Power Design : (3 -phase for CPU, 2 -phase for iGPU) - Industry leading Digital 1 Phase DRAM Power Design ASUS Quiet Thermal Solution : - Stylish Fanless Design Heat-sink solution ASUS EZ DIY : - ASUS CrashFree BIOS 3 - ASUS EZ Flash Operating System Support Windows® 10 Windows® 8.1 Windows® 7 SP1 Windows® Server 2008 R2 Windows® Server 2012 R2 Back I/O Ports 1 x DVI-D 1 x DisplayPort 1 x HDMI 2 x LAN (RJ45) port(s) 1 x USB 3.1 Type-A 1 x USB 3.1 Type-C 4 x USB 3.0 1 x Optical S/PDIF out 1 x 8-channel Audio I/O 1 x VGA Internal I/O Ports 1 x AAFP connector 1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s) 2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s) 2 x M.2 Socket 3 1 x COM port(s) connector(s) 8 x SATA 6Gb/s connector(s) 1 x CPU OPT Fan connector(s) (1 x 4 -pin) 1 x CPU fan with PWM control 4 x Chassis Fan connector(s) (4 x 4 -pin) 1 x S/PDIF out header(s) 1 x 8-pin EATX 12 V Power connector 1 x 6-pin EATX 12 V_1 Power connector(s) 1 x 24-pin EATX Power connector(s) 1 x System panel(s) (Q-Connector) 1 x DRCT header(s) 1 x MemOK! button(s) 1 x EPU switch(es) 1 x Power-on button(s) 1 x Clear CMOS button(s) 1 x USB BIOS Flashback button(s) 1 x 14-1 pin TPM connector Accessories User's manual I/O Shield 1 x COM port cable(s) 8 x SATA 6Gb/s cable(s) 2 x M.2 Screw Package 1 x Q-connector(s) (2 in 1) 1 x SCD BIOS 16 MB Flash ROM, EFI AMI BIOS, PnP, DMI3.0, WfM2.0, SM BIOS 3.0, ACPI 5.0a, ASUS EZ Flash Utility, ASUS CrashFree BIOS 3 Manageability WfM 2.0, DMI 3.0, WOL by PME, WOR by PME, PXE Form Factor ATX Form Factor 12 inch x 9.6 inch ( 30.5 cm x 24.4 cm ) Note *1 Switched from PCIEX16_1 *2 From PCH *3 6 x SATA 6Gb/s with 2* M.2 (SATA 6Gb/s & PCIe Gen3 x1 link, NGFF 22110/2280/2260/2242) *4 6 x USB 3.0 ports (2 ports Type A at front panel, 4 ports Type A at back panel)
