BIOS PC ASUS N3050T
Discussion in 'BIOS/UEFI' started by technical, Sep 5, 2016.
    ASUS N3050T
    BIOS N3050T-SI-0402
      Intel® Celeron® Dual-Core N3050 SoC onboard Processors
      2 x SO-DIMM, Max. 8GB, DDR3 1600/1066 MHz Non-ECC, Un-buffered Memory *1
      Dual Channel Memory Architecture
      * Refer to www.asus.com for the Memory QVL (Qualified Vendors Lists).
      Integrated Graphics Processor
      Multi-VGA output support : HDMI/RGB/LVDS ports
      - Supports HDMI with max. resolution 3840 x 2160 @ 30 Hz
      - Supports LVDS with max. resolution 1920 x 1200 @ 60 Hz
      - Supports RGB with max. resolution 1920 x 1200 @ 60 Hz
      Maximum shared memory of 512 MB
      Supports up to 3 displays simultaneously
      1 x mini-PCIe (full-length)
      1 x mini-PCIe (half-length)
      2 x SATA 6Gb/s port(s),
      1 x mini-SATA 6Gb/s port(s)*2,
      Realtek® RTL8111H, 1 x Gigabit LAN Controller(s)
      Realtek® ALC887-VD2 8-Channel High Definition Audio CODEC
      - Supports : Jack-detection, Front Panel Jack-retasking
      Built-in Controller :
      4 x USB 3.0 port(s) (4 at back panel, )
      GL852G USB Hub :
      5 x USB 2.0 port(s) (5 at mid-board)
      ASUS 5X Protection :
      - ASUS LANGuard - Advanced LAN protection
      - ASUS Enhanced DRAM Overcurrent Protection - Short circuit damage prevention
      - ASUS ESD Guards - Enhanced ESD protection
      - ASUS High-Quality 5K-Hour Solid Capacitors - 2.5x long lifespan with excellent durability
      - ASUS Stainless Steel Back I/O - 3x more durable corrosion-resistant coating
      - USB 3.0 Boost
      - Mobo Connect
      ASUS Quiet Thermal Solution :
      - ASUS Fan Xpert
      - ASUS EZ Flash 3
      - Push Notice
      100% All High-quality Conductive Polymer Capacitors
      Media Streamer
      Windows® 7 , 64bit
      1 x D-Sub
      1 x LAN (RJ45) port(s)
      4 x USB 3.0
      2 x Audio jack(s)
      1 x DC power connector(s)
      3 x USB 2.0 connector(s) support(s) additional 5 USB 2.0 port(s)
      1 x COM port(s) connector(s)
      2 x SATA 6Gb/s connector(s)
      1 x SATA power connector(s)
      1 x mSATA connector
      1 x CPU Fan connector(s) (1 x 4 -pin)
      1 x Chassis Fan connector(s) (1 x 4 -pin)
      1 x Internal speaker connector(s)
      1 x Chassis Intrusion connector(s)
      1 x 2-pin internal DC power connector
      1 x Stereo speaker connector
      1 x DMIC header
      1 x LVDS connector(s)
      1 x 14-1 pin TPM connector
      1 x System panel connector
      1 x Display panel backlight power selector
      1 x Flat panel display brightness connector
      1 x Display panel VCC power selector
      1 x LCD panel monitor switch header
      Thin Mini ITX I/O Shield
      1 x SATA power cable
      2 x SATA 6Gb/s cable(s)
      1 x Mini PCIe Screw Package
      64 Mb Flash ROM, UEFI AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.8, ACPI 5.0, Multi-language BIOS, ASUS EZ Flash 3, ASUS CrashFree BIOS 3, My Favorites, Quick Note, Last Modified log, F12 PrintScreen, F3 Shortcut functions and ASUS DRAM SPD (Serial Presence Detect) memory information
      WfM 2.0, DMI 2.0, WOL by PME, PXE
      EZ Update
      Thin Mini ITX Form Factor
      6.7 inch x 6.7 inch ( 17 cm x 17 cm )
      *1 Support both 1.35V DDR3L and 1.5V DDR3
      *2 mSATA shares the same slot with the full-length mini-PCIe card. mSATA shares the same bandwidth with SATA6G_2 slot. When a device is installed on the SATA6G_2 slot, the mSATA device is disabled.
      *DC in connector dimension: 7.4 x 5.1mm, Support both 19V and 12V DC input
      P_setting_fff_1_90_end_500.png-2.
    Similar Threads - ASUS N3050T Forum Date
    ASUS X411UA Schematic Schematics Apr 22, 2020
