BIOS PC ASUS J1900I-C
Discussion in 'BIOS/UEFI' started by technical, Sep 5, 2016.
    ASUS J1900I-C
    BIOS J1900I-C-SI-0806
      Intel® Celeron® Quad-Core J1900 SoC onboard Processors
      2 x SO-DIMM, Max. 8GB, DDR3L 1333 MHz Non-ECC, Un-buffered Memory
      Dual Channel Memory Architecture
      * Refer to www.asus.com for the Memory QVL (Qualified Vendors Lists).
      Integrated Graphics Processor
      Multi-VGA output support : HDMI/RGB ports
      - Supports HDMI with max. resolution 1920 x 1080 @ 60 Hz
      - Supports RGB with max. resolution 2560 x 1600 @ 60 Hz
      Maximum shared memory of 512 MB
      Supports DirectX 11
      1 x PCIe 2.0 x1
      1 x mini-PCIe *2
      Built-in Controller :
      2 x SATA 3Gb/s port(s), dark brown
      Supports Intel® Smart Connect Technology
      Realtek® RTL8111G, 1 x Gigabit LAN Controller(s)
      Realtek® ALC887-VD 8-Channel High Definition Audio CODEC *1
      - Supports : Jack-detection, Front Panel Jack-retasking
      1 x USB 3.0 port(s) (1 at back panel, blue)
      6 x USB 2.0 port(s) (4 at back panel, , 2 at mid-board)
      - Anti-Surge
      - ASUS UEFI BIOS EZ Mode featuring friendly graphics user interface
      - Network iControl
      - USB 3.0 Boost
      ASUS Quiet Thermal Solution :
      - ASUS Fan Xpert
      - ASUS EZ Flash 2
      - ASUS MyLogo 2
      100% All High-quality Conductive Polymer Capacitors
      Windows® 8.1
      Windows® 8
      Windows® 7
      Please update your BIOS and drivers to the latest version to support Windows 7
      1 x PS/2 keyboard/mouse combo port(s)
      1 x D-Sub
      1 x LAN (RJ45) port(s)
      1 x USB 3.0
      4 x USB 2.0
      1 x COM port(s)
      3 x Audio jack(s)
      1 x USB 2.0 connector(s) support(s) additional 2 USB 2.0 port(s)
      1 x TPM header
      1 x LPT header
      1 x COM port(s) connector(s)
      2 x SATA 3Gb/s connector(s)
      1 x CPU Fan connector(s)
      1 x Chassis Fan connector(s)
      1 x 4-pin ATX 12V Power connector(s)
      1 x System panel(s)
      1 x Clear CMOS jumper(s)
      1 x Buzzer
      2 x SATA 3Gb/s cable(s)
      64 Mb Flash ROM, UEFI AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.7, ACPI 2.0a, Multi-language BIOS, ASUS EZ Flash 2, ASUS CrashFree BIOS 3, My Favorites, Quick Note, Last Modified log, F12 PrintScreen, F3 Shortcut functions and ASUS DRAM SPD (Serial Presence Detect) memory information
      WfM 2.0, DMI 2.0, WOL by PME, PXE
      EZ Update
      Mini ITX Form Factor
      6.7 inch x 6.7 inch ( 17 cm x 17 cm )
      *1:Use a chassis with HD audio module in the front panel to support an 8-channel audio output.
      *2:This socket does not support USB Bluetooth signals.
      (The PCI Express x1 slots conform to PCI Express 2.0 standard)
      *3:please update your BIOS and drivers to the latest version to support Windows 7.
    Similar Threads - ASUS J1900I Forum Date
    ASUS X411UA Schematic Schematics Apr 22, 2020
