Asus ASUS K52JB REV 2.0
Discussion in 'Schematics' started by technical, Dec 5, 2014.
    ASUS K52JB REV 2.0
    BOARDVIEW
    Similar Threads - ASUS K52JB Forum Date
    ASUS X411UA Schematic Schematics Apr 22, 2020
  3. bga
    bga Moderator
    Images
    K52JB K52JR r2.0
  4. 27ifix
    27ifix Moderator
    i need the bios Asus X52J (K52JR) Bios Asus X52J (K52JR) Bios 4 MB
    thanks
  6. ormcra
    ormcra New Member
    Bios for ASUS K52JR REV. 2.3A?
  8. 02ifix
    02ifix Well-Known Member
    k52JB board k52JR 2.0 wich is the good bios for this model ?
  10. 02ifix
    nop , your bios doesn't display image ,
    my bios as only password and i cant remove it .
    • k2.bin
      4 MB
      13
  11. 02ifix
    indeed my gpu is a ATi 216-0728014
  12. technical
  13. 02ifix
    please remove the password on my bios , this bios you sent , simple dont display image . thk uyou !
  14. technical
    send one photo password i see ?
  15. 02ifix
    here it is
  16. technical
    you sure here is file you send me above ?
  17. technical
    K52JR REV 2.0
  18. 01ifix
    01ifix Well-Known Member
    hola luis tu equipo entra a windows o solo aparece la pantalla de password,
    por que hay un bypass dentro de windows cambiando la fecha del ordenador y con un codigo
  19. 02ifix
    b4rdock , pero non , en lo começo que lo ligo aparece luego la pantalla de password bios ( porque non tiene hdd )
    thienbuy , yes i am 100% sure , i know its crazy but the K2.bin itws the original bios on the computer and the client bringed the computer to our lab just because of that , he restarted the computer for something and after that it started asking a password on the beggining . so thats why im asking to remove password on this bios or give a perfect working bios without password .
  20. 02ifix
    with the latest bios you gave me , password is removed .
  21. 03ifix
    03ifix Moderator
    Asus laptop if remove bios password only need rescue date ALT/R press show date without program bios remove password.
