IBM-Lenovo X240S VIUX1 NM-A091 REV 1.0
Discussion in 'BIOS/UEFI' started by technical, Nov 6, 2014.
    file this and file above is same or other ??
  2. Arun
    Arun Well-Known Member
    other, i uploaded my password dump, your dump also having password
  3. Arun
    i need a clean file
  4. dan1200rr
    dan1200rr Well-Known Member
    Please remove a BIOS Password from my X250 (NM-A091 Mainboard) Bios dump file - I think that the Password is in this dump, because there is no U22. Many Thanks!
    Lenovo Password not have in file bios.
  6. Arun
    then where is it correctly. send clean mec 1633 file
  7. Arun
    HERE IS THE MODEL DETAILS CLEARLY
    X240 NM-A091 REV 1.0
  8. dan1200rr
    When the Password is not in the Bios dump file and there is no U22 (EEPROM storage for Password), according to the schematic and this table - it means that the Password is stored in a U23 (MEC1633L) ?? To delete a Password I need to flash MEC1633L ?
      131 KB
      2
    right MEC1633 have rom.
  10. dan1200rr
    But You didn't answer the question - flashing the MEC with SVOD Programmer will delete the Password? I need to pull out new EC dump from my original BIOS dump and flash with it?
    KONTER likes this.
    We provided file rom ec mec here
    https://vinafix.com/threads/x240s-viux1-nm-a091-rev-1-0.11718/#post-74317
    you need downloads and Programming to ec mec for you have password, end.
  12. 03ifix
    03ifix Moderator
    Yes program the MEC password will remove.
  13. Arun
  14. Arun
    kindly give me the clean mec file. i attached my old mec dump and model detials. X240 NM-A091
  16. Arun
    NEW EC FILE NOT WORKING, LAPTOP GOES NO POWER ON:nrg::nrg::nrg::nrg::mad::mad::mad::mad:
    PLEASE GIVE WORKING FILE....:cheers:
  17. Arun
  18. technical
    check hardware.
  19. Arun
    Mistake was mine, for super visor password in x240, no use of flashing main bios 16 mb and ec rom mec1633 192 kb, because password stored in separate 2kb storage of mec1633 ic.
  20. IO81
    IO81 Well-Known Member
    j
    Hi please need romT460 and jtag points thanks
