Acer-Gateway E5-571G - LA-B991P
Discussion in 'BIOS/UEFI' started by technical, Jul 20, 2015.
    Core i3,i5,i7 use same bios, you can send old bios i check me region.
  2. Salutit
    Salutit New Member
    hello, do you have ec for this mb ? Kb is 9022 not 9012, it's a i5 5th gen with nVidia 820 and if you have bios dump that will be great. 10x
  4. bruce
    bruce Well-Known Member
    THIS FILE IS IS SAME FOR KB9022Q SAME MODEL BOARD
    yes, only same motherboard code.
  6. M.SREE KUMAR
    M.SREE KUMAR New Member
    i need i/o chip program 128kb
    yes, update on top.
  8. KPK LAPTOPS
    KPK LAPTOPS New Member
    i need bios for Acer e5-571g 53nr
    A5WAH LA-B991P
    All bios Above Not Work
  9. KPK LAPTOPS
    This Bios Don't Have Display
  10. technical
    many problem, old bios error what ?
  11. KPK LAPTOPS
    old bios don't have display
  12. technical
    all bios is no display you need check hardware.
  13. brandsite
    brandsite Well-Known Member
    pl
    plz upload ok bios
  14. technical
    wow.
    details the issue as a result of the BIOS programming above. or say i know how is one bios ok?? :(
  15. Saad Rafeeq
    Saad Rafeeq Well-Known Member
    acer v3-572g-76EM
    laptop turn off after 4 seconds
    need solution
    A5WAH LA-B991p rev 1.0
    • old.BIN
      22
  16. technical
    have display or no ?
  17. Saad Rafeeq
    no display
  18. Saad Rafeeq
    please brother help
    give me solution
  19. technical
    try it
  20. 07ifix
    07ifix Moderator
    i send old bios having no display please now rebuilt this old one la-b991p
Similar Threads - 571G B991P Forum Date
Acer-Gateway Acer aspire EK_571G Z5WAH LA-B991P r0.2 Schematics Dec 11, 2015
ACER E1-571G LA-9012P REV 2.0 BIOS/UEFI Feb 22, 2019
EK-571G-50DE BIOS/UEFI Dec 29, 2018
Acer E5-571G dont go on Computer Hardware Repair Oct 7, 2017
Acer Asppire V5-571PG/V5-571G 11309 Remove Password Computer Hardware Repair Jan 2, 2017
