Apple iMac A1419 820-4652
Discussion in 'BIOS/UEFI' started by technical, Sep 18, 2016.
  1. Nenad63
    Nenad63 New Member
    Is it possible that the N25Q064A chip is bad, so I can check it out? Although the programming goes smoothly ... thanks
  2. technical
    iMac Intel 27
  3. Nenad63
    Nenad63 New Member
    I know where it is, but how do I check it?
    check what?
  5. Nenad63
    Nenad63 New Member
    N25Q064A Chip
  6. technical
    here is BIOS you need Programming, you say check what i not Understand. :(
    Are you a technician and know the BIOS programmer?
  7. Nenad63
    Nenad63 New Member
    Pictures while iMac was in use
      799 KB
      9
      454.5 KB
      8
      413.4 KB
      7
      1.3 MB
      10
      296.4 KB
      8
  8. technical
    answer the question Please :
  9. Nenad63
    Nenad63 New Member
    Can I ask you to make Clear ME from Apple iMac A1419 820-4652-A.bin file ... please
  10. technical
    Clear me A1416 820-4652-A.bin
  11. Nenad63
    Nenad63 New Member
    Why A1416, not A1419 or is a mistake in writing
  12. technical
    only need same code 820-xxxx. :)
  13. Nenad63
    Nenad63 New Member
    Here's one more time. Most likely the bios dump does not fit my CPU: Intel Core i5 3.5Ghz .... can you fit it ...Sorry , I'm using a google translator...Can you make a Clean ME from an Apple iMac A1419 820-4652-A bin file, not from A1416 820-4652-A mx25L6406e.bin
  14. technical
    send file i help clear me.
    or use guile this.
    https://vinafix.com/resources/how-to-clear-me-region.1188/
  15. gadgetfix
    gadgetfix New Member
    anyone have schematic or boardview for this? I have blown fuse not sure what spec?
  16. technical
    yes, Unavailable schematic
  17. 41ifix
    41ifix Well-Known Member
  18. 05ifix
    05ifix Moderator
    Got it!
    Here ya go!
    01ifix and 41ifix like this.
  19. 41ifix
    Nice bro +1
Similar Threads - Apple iMac A1419 Forum Date
Apple iMac A1419 820-3478-A BIOS/UEFI Dec 22, 2015
Apple Apple iMac 27 A1419 D8 051-9505 820-3299_051-9505 800 Schematics Jan 6, 2014
APPLE iMac 21.5" A1418 820-01061-A BIOS/UEFI Aug 17, 2019
820-00609-A Apple iMac 27" 5K Retina BIOS/UEFI May 26, 2018
Apple.HD6970M.2048.110128 (IMAC A1312 HD6970 2GB VGA ATI 216-0811000) ELECTRONIC DEVICE Sep 24, 2017
