HP 2000-2200 Notebook PC series
Discussion in 'BIOS/UEFI' started by technical, Aug 10, 2015.
  1. ganesha
    ganesha Well-Known Member
    pl provide clearme for this file
  2. technical
  3. brandsite
    brandsite Well-Known Member
    this my problem warning me pch not matching plz send me bios file
  4. brandsite
    its urgent
    What have you changed and repaired?
  6. brandsite
    HM CHANGE ONLY SLJ8E HM77
    HM77 change to HM77 or other ?
    backup send i file bios.
  8. brandsite
    HM 70 TO HM 77 OLD BIOS SAME ERROR COMES
    yes, send file old i help fix.
  10. brandsite
    MY OLD FILE
    • me.bin
      4 MB
      14
  12. brandsite
    SAME ERROR
    i think can is problem chipset and CPU.. try need try check again.
  14. brandsite
    LA-B181P MOTHERBOR IS LET DISIPALY MY OLD FIL IS SENT
    here is version new late you can try.
  16. brandsite
    i chek 2 cpu replace already and 3 chip hm77 also i have total 5 board with same problm help me
  17. brandsite
    same issue and your bios add product error serial no error also send me ok bios plz
  18. technical
    same problem not need add info, check chipset.
Similar Threads - 2000 2200 Notebook Forum Date
HP-Compaq HP CQ20-2230s-(6050a2200001 MAB-A02) BIOS/UEFI May 28, 2014
HP-Compaq HP 2230S 6050A2200001-MB-A03 Schematics Feb 23, 2014
TV Bravis LED-32D2000 chassis TP.VST59S.PB703 ELECTRONIC DEVICE Jun 20, 2019
Dell Quadro M2000M 4 GB BIOS ELECTRONIC DEVICE Mar 7, 2019
TV KONKA LED42E330CE 72000141YT V0 ELECTRONIC DEVICE Dec 22, 2018
